Macomb County file?
fregan
Sterling Heights, Michigan
Hi all, this is my first post here. I have a major issue: I have a Uniden BCD996T that was programmed nicely for all of Macomb County until yesterday, when it displayed "finding control channel" I have not seen that before. Has the control channel frequency changed?
Anyway, I tried to find the new control channel's frequency and really screwed up my scanner. I downloaded FreeScan and Proscan to see if I could reprogram the scanner and realized I need a file or database of frequencies for Macomb County.
Does anyone have a file of Macomb County frequencies and would they be willing to share it?
I did check in the database for two frequencies of 853.26250 and 853.9875 and tried inputting them into the scanner--no luck.
Boy I sure could use some help here. Thanks.
krokus
Southeastern Michigan
Wirelessly posted (Opera/9.80 (Android 2.3.4; Linux; Opera Mobi/ADR-1309251116) Presto/2.11.355 Version/12.10)
Did you input to new control channels as a trunking frequency? Uniden treats them differently, so you must input them in the correct mode.
