MacOS Mojaave and Ladiocast
Stavro35
Bainbridge Island, WA
After updating to the latest MacOS . I can't get my scanner feed to work properly. I've been using Butt and Ladiocast. Butt, works fine, since the update to MacOS Mojave. Ladiiocast is not.Should I go back to the previous operating system? Or, is there an alternative combionation, or single software solution to get my scanner feed back online?
ko6jw_2
Santa Ynez, CA
LadioCast is available in the App Store and should be compatible with Mohave otherwise Apple would not make it available. Developer licenses require all sellers to be compatible with new OS. I'm using a MacBook and the store says it will run on my computer. I run Broadcastify streams on iTunes. Seems to work fine although I rarely use it.
Try downloading LadioCast again from the App Store. There may be a new version.
Mohave has some neat new features. Don't go back.
Stavro35
"Check the network environment or the connection configuration." is the error message I get. I've configured Ladiocast to the specifications. And the software "butt" actually connects. But Ladiocast still won't.
