madison co
mlufib
Does anyone have any recommendations for a scanner that can receive Madison county, Anderson, and the Indiana state police? i guess Madison county and the Anderson police both use different ltr systems.
racin06
Westfield, Indiana
scannerfreak
Well Known Member
Indiana
The city of Anderson uses an EFJ Multi-Net System. The only way follow or track the system is to utilize the LTRUNK program. You can monitor it conventionally, see the TRS page for more info:
http://radioreference.com/modules.php?name=TRSDB&sid=943
mlufib
LTRUNK
Will LTRUNK run on the Uniden BC-296D.
If so does it require a computer to be connected to the scanner to run or does it just need a computer to load the program into the scanner?
Thanks for your help
scannerfreak
Well Known Member
Indiana
First, you need a discriminator tap in your scanner. You can tap any 800 MHz capable scanner. Do a search of the forums here and even google and you'll find all the info you need!
