AlphaFive
I am studying the very basics of magnetic loop antennas, I do not have one. I am trying to learn about proper location and mounting. In the most generic terms, it appears a horizontal mounting of a magnetic loop should produce a general omnidirectional antenna, and a vertical mounting of a magnetic loop should produce a directional antenna. In the most basic terms, is this correct??
I have found from reading that there are countless numbers of homemade loops, and plenty of commercially produced loops. And because of the wide variety, there are no set answers for exact placement and setting on any particular angle. I am simply trying to make sure I understand the fundamental concept of horizontal = omnidirectional vertical = dual directional, that's all. Thank you all for your time and help, take care.
I would like to save the discussion regarding a proper height of a horizontally mounted antenna for another day, I have read those, and even I know that can get lengthy, thanks..
Also, I realize FM is line of sight, so the term 'omnidirectional' in horizontal position isn't 100 % accurate, but I just want to make sure I grasp the concept. My interest would be more toward MW and SW, so FM isn't a large factor.
