Mag One BPR40 solid green light
BC_12
Merrimack New Hampshire
If the radio is programmed to a random set of Freqs and DPL/PL
the light is solid green as soon as I turn on the radio
if I set to factory defaults the light is not on and the radio can communicate on those channels
Has anyone experienced this?
BC
BC_12
Setting to tight
When set to tight it helped on one radio
Question still remains why 464.5 would work but 461.2 will not work25 radios work and 4 do not!!!
RFI-EMI-GUY
You should not have to set squelch tight. Try this, remove the antennas and move away from noise sources like your computer and monitor. Does the light go off? If so, use default squelch settings which should be threshold not tight and blame the noise from your computer for opening the squelch on those frequencies.
RFI-EMI-GUY
also check the programmable button for PL/DPL disable. Is it programmed to work? have you toggled it? The light normally should be amber if interference or co channel activity. There might also be a programmable feature that inhibits transmit if there is other activity on the channel. You might want to turn that feature off to prevent confusion.
Personally, I would reset to factory defaults, read the radio, change the frequencies and rewrite to the radio just in case there is an error in the codeplug template you are using.
BlueDevil
WA
I am experiencing the exact same issue with a batch of Motorola MagOne BPR40 UHF radios. All of the radios are using the same codeplug (R02.01.UV2). The issue came about during a programming update and specifically bringing the radios within narrowband compliance. If the radios are restored to the factory default of wideband operation they operate fine. However after narrowbanding these radios the green light stays on and the transmitter and receiver seem to have drifted off alignment. Many of these radios have chronological serial numbers making me wonder if they were a bad batch from the factory.
Here are a couple short video clips of the radio before and after reprogramming and narrow banding the radios:
https://youtu.be/PBq2PIRDWVA
https://youtu.be/hmiIUexY4d0
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
.....dreaded bad narrow band filter issue. If radios only exhibit this issue during narrowband operation, it is indicative of bad narrowband filters. Have had hundreds of these through the shop for this issue. TT
llu727
New Jersey
+1 on crystal filters.
I ALWAYS change both at the same time since it is so much fun to do.
Generally, after removal - break it open and you will find green stuff growing in them.
BC_12
Filters
Decided to take a swing at replacing these filters. Can you tell me the part number and source to puschase them. I would appreciate it very much.
Thanks BC_12
