MarkEagleUSA
Everyone (at least the experts here) seems to swear that a scanner antenna needs to be grounded on a vehicle to work properly. I've read where it is crucial for transmitting (i.e. CB, etc), but I wonder about reception.
I have an Antenex mini NMO mag-mount and I just recieved this ultra-mini mag mount. The Antenex has a rubber boot around the magnet and the ultra-mini has a plastic base. Neither one grounds to the vehicle via the magnetic area, and since they're used with handhelds, there's no electrical ground connection through the radio.
Is there some sort of magic happening that I'm not aware of, or is there really no ground, and if not, how is reception affected?
Would a standard NMO body-mount on the Antenex offer improved reception because it would be grounded to the vehicle?
One final question: if they're really not grounded (nor need to be) would any magnetic mount antenna serve as a poor-man's base antenna? I'm not looking to pull signals from 50 miles away... I just want to improve on the standard rubber handheld antenna.
