mAh question
jpm
I'm looking into the aaa chargeable batteries more so when i go on vacation with the handheld scanner to quickly change them. my question is in mAh if one goes from 1500mAh to 750mAh what is the consequences on the scanner.
N
N_Jay
Guest
In theory it will only run 1/2 as long.
In practice, Hmmm I would guess about the same, but +/- a good bit.
rfaricy
Gulfport, FL
With 750 mAh, your scanner will run for about three hours. Why do you want less? You want MORE current-hours... 2300 mAh will run it for almost 16 hours.
Get the 2300s at a Wal Mart (cheap!) or a camera store or something... I bought some Quantaray 2800s with an ultra-fast charger. Works great.
And you want DOUBLE-A (AA), _NOT_ triple-A (AAA).
jpm
Thanks for the quick response. I'm using 2500mAh for my digital needs now. this is for the 250d going on vacation.
loumaag
Silent Key - Aug 2014
Katy, TX
jpm said:
...this is for the 250d going on vacation.
When did the 250D start taking loose batteries as opposed to the propriatary battery pack?
Voyager
Someone found that a AAA 4-pack will fit in the compartment on the 250.
A AA 4-pack will not.
Joe M.
