Make my own UHF antenna...
conve36
Menifee/Lake Elsinore, Ca
Can someone tell me how I can make a transmitting antenna for GMRS using a mag-mount. What is the difference between a quarter-wave antenna and full-wave? I know its the length, but whats better?
Tulsa
Quarter wave. Antennas present an acceptable impedence at a quarter wave and odd multiples thereof. Half wave and even multiples thereof present a very high impedence without a matching network to transform the high impedence to a nominal 50 ohm impedence.
Don't be tempted to make a 3/4 wave antenna it will give you an acceptable match but the radiation pattern maximum will no longer be toward the horizon but will be elevated at about a 40 degree angle; great if you want to communitcate with the birds.
w8jjr
Lincoln MI
The best bet is to used a swr meter and start at 7 " trim alittle off at a time till you get a reading of 1.5:1 or better.
1:1 is perfect and most of the time theoretically unobtainable, but we can get close.
1.1:1 is almost perfect, thus this is very good
1.5:1 is good enough for almost every purpose, and is not to bad
2:1 is getting into the questionable zone. The value is getting high enough to cause
problems in some cases.
3:1 is the generally top accepted limit 3:1 SWR will cause problems in many cases. And may indicate a short.
