Just about any antenna will receive some signals on just about any frequency. The question is: How well will it work, will it be an improvement over the stock antenna? Without using test equipment to determine the proper length to be resonant at 800MHz, cutting a stock loaded antenna will be just trial and error. It may work better at 800MHz, it may be worse. The problem is, once you cut it, it's done, and you can't undo it.
I took a UHF rubber duck six inch whip and cut it down to about three inches, and it did improve reception at 800MHz. But this was not a stock loaded antenna, it was a quarter wave whip, so the results were more predictable.
You can either try it and see, or else purchase a ready made stubby antenna.
