making an antenna
friedthat
outside Waterloo
I was wondering; i have an old ducky that i took apart (unwound and ripped the plastic rubber off of it. Now if i want to make this long vertical wire for a specific band i.e 400-430Mhz should i use quarter wave calculation or half wave to cut it to length?
friedthat
outside Waterloo
so why would one be better at half wave and the other be better at 1/4 wave? ALSO what about distance. if the site is farther away i.e 20 miles or so which wavelength should i go with 1/2 1/4 or 5/8?
Don_Burke
Southeastern Virginia
A coaxial antenna is two quarter wave elements that make up a half wave antenna.
For 20 miles, I would forget the duck and put something outside.
