Making an IC-R7000 act like a scanner
I have an ICOM IC-R7000 (Communications Receiver 25-1300 MHz) and well it is a great radio ... but as a scanner well not so sure. I love the radio .. but this is a little annoying.
What I am interested in is making the R7000 act like a NORMAL scanner. Just scanning the frequencies and sit on an active frequency and continue when the transmission is over. This would be what it would do continuously ...
I am wanting to monitor a control channel of a Trunking system .. thus I want it to stay on the control channel until it changes, then move on as required.
This is what I find mine does ... scans the memory channels but when it gets thru ONE pass of the memory channels it SHUTS THE SCAN OFF. I want it to scan continuously ...
Am I doing something wrong .. or can the R7000 not act like a normal scanner ?
All help is appreciated.
VE6RHS
Chetwynd, BC Canada
Which Scan mode are you using?
The "Selected Mode" scan and the "Selected Memory" scan modes should work fine.
Check section 5-5 of your manual. The manual is written in "Icomese", so you may have to read the manual 2 or 3 times to figure out the TRUE meaning or the various scan modes.
Enjoy!
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
FYI - Altho the receiver is not really a scanner, there are a few software packages out there which should at least make it approach a scanner. RadioMax in particular has been tested out and I can highly recommend it. I've personally not used it with the R7000, but the reviews on the wiki page at:
http://wiki.radioreference.com/index.php/IC-R7000
have (I used it with a 895). It won't be blazing fast, but it will be somewhat better. And according to some recent comments in MT, RadioMax is quite stable on XP.
I use this software as my weapon of choice when scanning UHF milair.
73s Mike
bsmotril
Central TX
R7000 scanning
When the R7000 came out, Icom ended up in some patent disputes with a scanner maker (bearcat??). Hence, the funky scan delay settings with no auto-resume after the squelch closes. They could not add that feature because it was covered by a compeititors patent. BillS
Al42
Long Island, NY, USA
Why? You like listening to digital noise?
Unless it's a trunk tracking scanner, the control channel never changes until the system changes control channels, if ever (some don't).
Thanks for the replies ..
Yes it is a bit of a pain that the radio wont operate like a scanner. I will try that software.
MacombMonitor
The Icom IC-R7000 is a great communications receiver, but a poor scanner as Mike pointed out. I've owned a couple over the years, and believe me when I tell you, even with the best software you can find, you won't be happy trying to use it as a scanner. It's good for sitting on a particular frequency, waiting for something to happen, as in surveillance work. Or thumbing the tuning knob, in an effort to seek out new frequencies within a small range.
You'll probably be happier and less frustrated if you sell the Icom, and put the money toward a PRO-2096, or BCD996T.
Bill
