Manatee County Help
NarcSgt
Need some help. I see one frequency for Manatee Fire/EMS. There must be more frequencies that they dispatch on but I can't find any. Any help? Thank you
NarcSgt
Thanks....if you have the proper scanner will it pick up some of the close frequencies of the trunk?
Ranger0034
Clearwater, FL
Jack, ID search feature will pick up any unpublished talk groups. That's part of the fun of scanner listening theses days is to hunt down and try to determine who unpublished talk groups belong to on a particular trunked system, and when verified, submitting them to the RRDB.
maus92
OCMD
This is the system you will need to monitor:
It is a P25P2 simulcast system, so you will need buy a radio (or use a software solution) that is capable of properly handling the multipath interference that is common with simulcast systems. You don't need to be concerned with "close frequencies," but you probably need to monitor the Manatee County Simulcast site to receive Manatee County agencies
