Manchester, CT - Manchester Police Upgrade Radio System
PhillyPhoto
Wethersfield, CT
I wonder if they'll go digital like Vernon, South Windsor and Glastonbury (although they're 800MHz). It would make sense since they have the tri-town Narcotics Task Force.
mbnv992
AZ
I'd vote they are going UHF P25 for sure. Vernon, South Windsor, Enfield, etc. are already there. I'm sure East Hartford will be right behind them too. Only 800MHZ P25 departments local is Glastonbury. SW WAS 800MHZ, but switched to UHF.
bobmich52
I Hope the MPD bumps up the Transmit power Like the town fire dpt did
PD, Very scratchy reception in my area, FD comes in like I'm sitting in their parking lot
Ranger0034
Clearwater, FL
Eastern Central Narcotics Task Force is on Marcus' NEW Hytera Tier III system... so it cant be found or monitored either way... already encrypted
firerick100
wolcott ct
Correct me if I'm wrong but is Marcus one of the systems that can not be monitored with a scanner,I thought I read that somewhere in a post on another subject awhile back.
Ranger0034
Clearwater, FL
Marcus Communications has had two major trunked systems for years... Both LTR, one standard which can be entered and monitored and the other Passport which cannot be easily monitored... only by entering the freqs conventionally, which means the channels have to be scanned manually since the scanner will stop on each channel on not scan.
PhillyPhoto
Wethersfield, CT
They supposedly have a new DMR trunked system. Below is what I've put together from the FCC ULS DB, but I have no way to monitor it to confirm anything:
System Name: Marcus Communications DMR
County: CT-LITCHFIELD CT-NEW HAVEN CT-HARTFORD
System Type: Hytera DMR Tier III
System Voice: DMR
FCC License: WPFU401
Site 1 (Torrington, CT)
Unconfirmed LCN
461.10000 (1)
461.40000 (2)
463.70000 (3)
464.02500 (4)
Site 2 (Naugatuck, CT)
Unconfirmed LCN
461.52500 (1)
462.02500 (2)
463.25000 (3)
463.85000 (4)
Site 3 (Meriden, CT)
Unconfirmed LCN
462.00000 (1)
463.83500 (2)
464.70000 (3)
464.90000 (4)
Site 4 (Hartford, CT)
Unconfirmed LCN
461.32500
463.22500
Site 5 (Hartford, CT)
Unconfirmed LCN
462.10000 (1)
463.50000 (2)
463.90000 (3)
464.35000 (4)
