Manchester Trunked Radio System ProVoice
fog
I've never had the scanner stop on something that didn't come through, though... Nor have I noticed agencies like the police (who would probably be the ones wanting to use ProVoice) with conspicuously absent transmissions. I've actually only been monitoring Manchester for a week or two, but I'd upgrade LPD7's comment to, "There's no evidence to suggest they are."
I'm curious if it's planned at all, though, as the RadioReference listing mentions. That's several years out of date, so I wonder if it's been scrapped or just delayed.
Lynch_Christopher
Winthrop, Ma
Yeah I saw it in the radio reference database that's why i mentioned it. I have a feeling that they don't use the Provoice since i hear most of their communications on the regular trunked system. But then again i agree that even if they were using we probably wouldn't know since no scanners can pick it up.,
fog
Even the page at my Wiki is a little old, but maybe this will shed a little light.
All I see that's relevant is, "System- Analog with Pro-Voice Digital Interface," which is just as ambiguous as on the RadioReference site.
...even if they were using we probably wouldn't know since no scanners can pick it up.
Is the data sent out over the control channel any different depending on the format, though? I'd think that the radio would still tune to the appropriate frequency when it saw that a talkgroup was active, and then the ProVoice 'noise' would come out your speaker, much like monitoring P25 on an analog scanner. Unless the control channel indicates whether a transmission is analog or not.
KC1UA
Scan New England Janitor/Maintenance
Marstons Mills, Cape Cod, Massachusetts
Actually, that tells me that the system has the capability of using Pro-Voice. Not to mention, if they do, you won't be able to monitor it anyway. If information doesn't get updated at this site or at my site, maybe there's simply nothing to update.
How about using UniTrunker to see if any ProVoice talkgroups appear. If you've got a radio that has a discriminator tap that would be the best way to figure it out. If it shows a talkgroup labeled "Dig", there's your answer.
I'm guessing they are not (yet) using Provoice, as it's likely it would have been reported by now. There is a strong scanner community in NH that's really on top of things.
NYRHKY94
Brunswick County, NC
I believe Scott's analysis is correct. I've got a 24x7 feed running for Manchester Police & Fire and don't recall having any issues with missed communications etc.
CHRIS: As Scott mentioned, we do have a very knowlegeable scanner group in NH (lots of true radio guys). I would suggest joining the NH Scanner Yahoo Group and posting your questions there in addition to the RR site.
http://groups.yahoo.com/group/NewHampshireScanner/
Manchester, NH
From what I have observed, every time Manchester PD mentions "Coded" (as in: "...stand-by for a coded broadcast..." or "...try it again, you were coded..."), they are referring to ProVoice. Every scanner that I have used on the Manchester TRS won't acknowledge the ProVoice transmissions. However, if you manually step through the voice frequencies when there is a coded broadcast, you will hear the raw digital stream (without the ...beep, beep, beep, beep, beep at the end like analog).
During the Ofc. Briggs funeral, Manchester had 155.475 tied into the TRS. One of the captains told another unit to go coded. When they did, you couldn't hear them on the TRS. However, it was still patched through to 155.475 (I doubt they realized it though!).
They don't use it very often, as ProVoice coverage in the city is horrible.
fog
Today I heard them "go coded." The scanner doesn't stop, indicating that the system indicates it differently... But I stepped through the channels and heard digital traffic that definitely wasn't an EDACS control channel.
So scanmanchester was right: it's there, just used very rarely.
BTW, ProVoice isn't actually encrypted, is it? If I were to buy a radio that did ProVoice, wouldn't they be audible? (Of course, buying used radios and putting them on a system you don't have permission to be on is a horrible idea... I'm just saying, they seem to use ProVoice as encryption, whereas I don't think it's actually encrypted.)
Manchester, NH
This is what I've been able to find...
"...EDACS ProVoice digital now supports
DES encryption with FIPS-140 certi-
fication by the National Institute of
Standards and Technology...."
(From M/A-Com's EDACS Brochure http://www.macom-wireless.com/products/pve/default.asp
(Click on Brochure in the top paragraph - PDF File)
Also see: http://en.wikipedia.org/wiki/EDACS_Provoice
These tell me that ProVoice, itself, is actually in-the-clear digital... but is not decodable by any of the scanners on the market, thus making it pseudo-encrypted.
jmarcel66
Concord, NH
Yes Manchester uses encryption. I believe it was originally called "Aegis" or something like that. It pre-dated Pro-Voice. I think they are now on Pro-Voice and "Go Coded" means use the encryption. It is typically tied to the talkgroup they are on as opposed to separate talkgroups.
The term dates back to their High-Band days (156.210 Ch-1, 154.845 Ch-3) when they used DVP/DES encryption similar to what the fed's used to use before P25 encryption.
nhmedic12
manchester nh
Help I am getting confused
I just bought a new
Uniden BCD996XT Digital Mobile scanner and programming it is kicken my ***, is there anyone in the manchester area that can help
idle00955
Manch NH
I own a MA-Com P7170IP and Manchester does use Pro Voice every now and then. Its the same radio the police are using.
jrothwell
Manchester, NH
This is an old thread, but I have the same radio. The entire system is Provoice capable but it's only enabled on the PD talk groups and the PD are the only ones who have radios capable of it. They never use Provoice in the clear (like the MBTA) but when they "go coded" they are using encrypted Provoice. This system is going away in about a year when a new p25 trunked system goes online.
