I live in Manchester, and I can hear (almost) everything. The only things you won't hear is when MPD goes "coded". They do this for broadcasts, such as certain alarms, when there may be a chance that the subject of the broadcast (a person breaking into some place) has a scanner and can hear them. From what I understand, they use ProVoice encryption, so even a Pro96 or other digital scanner can't make sense of the digital coding. When they go "coded", the trunking system uses a different protocol for the transmission, which most (if not all) scanners simply ignore. You will just hear HQ call a couple of units.... a long pause... and then the units will acknowledge.
Hope this (long-winded) response helps!
