Manual for Uniden BC785D, help on programming trunked freq's
pete8528
Anyone know where I can find the BC785D manual online, let a friend borrow the manual and they lost it. Need help manually programming trunked freq's.
duckbird
Texas
Programming the 785D for Conventional Scanning
1. Press Menu
2. Press 2
3. Press 1
4. Select Channel No (You can use the VFO knob or wheel)
5. Press E
6. Press 1
7. Enter Frequency
8. Press E twice
9. Press 1
10. Use vfo knob or wheel to select next channel
11. Press E
12. Press 1
13. Repeat steps 7-11
To add alpha tag…Turn vfo knob until you see the letter or number you want.
To move forward, (On base scanners, press in on the vfo knob
On the handheld scanner, press RSM. When you finish, press E
Programming the785D For Trunking)
1. Press Menu
2. Press 2 twice
3. Select Bank
4. Press E
5. Press 1
6. Select On
7. Press E
8. Select System Type
9. Press E
10. Select Channel Number
11. Press E
12. Press 1
13. Enter Frequency
14. Press E twice
15. Use VFO knob or wheel to move to next channel
16. Press E
17. Press 1
18. Repeat steps 14-19 (When finished, Press Scan)
Adding Talk Group ID’s and Alpha Tags
1. Press Menu-2-2
2. Select Bank-Press E-3
3. Select Location-Press E-1-Enter ID-Press E
4. Press 2-Enter Alpha Tag by using the VFO knob or wheel-Press E
5. Press Menu
6. Repeat Steps 3 through 5
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
JMR said:
There is also a programming guide in the wiki but I dont have a link for that.
Wiki Main Page->Uniden Scanners->BC785D->Programming Shortcut BC785D
or
