Schnoor1648
- Joined
- Apr 27, 2003
- Messages
- 101
- Reaction score
- 0
I am in the Minneapolis-St. Paul Twin Cities Metropolitan area and I am interested in mapping the local LTR systems. I have been reading as much information as I can about determining details of LTR systems. It almost seems as if many or most of the old rules don't necessarily apply any more. For example:
-At one time I seem to recall that 5 frequencies were a minimum for trunked systems. I have actually read about 1 channel LTR systems.
-Frequency order used to often be either in ascending or descending order with respect to Home Channel Number, but now I read that this may also not always be the case.
-If a given licensee has frequencies in both the 450 and 460 sub-bands, is it likely that the 450 frequencies are in one system and the 460 frequencies another system, or does that not usually matter?
-I thought that any given frequency would only be a part of a single system in a certain area, but now I have read were a given frequency can be a part of different systems of the same licensee or even different licensees in the same area.
-I read that owners often space home channels evenly like 1, 5, 9, 13, 17, but now that seems no longer valid.
-When listening to frequencies conventionally, there may have been a transmission every 10 seconds, but now I read that this may also no longer always be the case.
-Apparently callsigns are not always good indicators of what frequencies belong to what system(s).
-I thought at one time that I read that the middle number in the ID is the Home Channel Number. Is that still the case, or is that also outdates?
-Apparently some trunked licensees can be IG or YG in the FCC database.
Anyway, I am looking for some good tips in figuring out my local systems. I have a Uniden Bearcat BC796D. I use the Butel ARC250/785 software. I also have other radios to monitor frequencies conventionally for activility.
What I have done so far is make a list of all frequencies withing about a 25 mile radius that are licensed for trunking. Then I listened to each one conventionally to see if there is the tell-tale burst every 10 seconds. From there I would enter a given frequency into the BC796 and scan it in the ID SEARCH mode. I have determined what I think are the correct Home Channel Numbers for a number of frequencies. What seems to be the stumbling block now is there are a couple of companies that have over 20 channels licensed in the area. Thus I think that they have more than one LTR system in the area. In fact, I suspect the at least one of the companies has 3 or more systems. How can I determine which frequencies go with which systems? For example, say a certain licensee has 463.725, 464.350, and 464.600 that all come up as Home Channel Number 1. How can I determine which other frequencies are part of say System 1, System 2, or System 3 of licensee "A"? One thought I am considering is to pick an active (and hopefully somewhat unique) talkgroups from a given frequency. Then I could program all ten banks in the BC796D with the ARC250 to see if that ID shows up on any other frequencies. Any thought on how likely this is to be accurate? Any other suggestions on how to map these? I do not have an Optocom, PRO-92/2067, or other radios that track LTR. I would just like to be able to accomplish this using the BC796D and Butel ARC250, if this is possible.
