Maps...
N5MRK
Oklahoma City, OK
Well... i remember a while back i made some maps of OKC and OHP so it would be easier to figure out which divisions had what parts of OKC and which troops had what parts of OK. I was just browsing the database and didn't see these maps on there. If someone wants to add them to the DB go for it. I hate to see them just sitting in my filedump... :p
http://www.mattrk.com/pics/OKC-Division-Map-Small.jpg - OKC Map
http://www.mattrk.com/pics/ohptroopmap.gif - Troop Map
-n5mrk
BCFD25
Now for a real challenge. Can you do the same thing for all of the OKC fire stations. That would be pretty cool. Then go thru and mark all of EMSA's posts. Talk about alot of work. You know you would think that someone somewhere had a map of the state with all of the fire districts marked off. Are there any true no man lands ? Sorry, just kinda thinkin out loud.
car2back
Tulsa, OK
we have a map off the Tulsa 911 area showing all the Fire districts in it at our station..... there isn't any "no mans land" around here, but there is some areas that have a dual response!
KD5WLX
Tulsa
Fire department maps (showing admin boundaries between where each dept is responsible) is not too bad, but maps for "within" a fire department can get a little tricky. You see, every address is mapped to a list of engines, trucks (ladders), chiefs, brush rigs, etc. IN ORDER by which is closest (by real road time, not as the crow flies).
Dispatch matches the type of assignment (x engines, y trucks, z chiefs) to the "available" list (excluding those that are out of service) and "fills" the assignment.
About the only way you can do a "district" map for a fire department is to map the 1st due engines - they're typically 1 per station. You'd need a second map for 1st due truck, with larger areas (trucks are typically about 1:3 to engines) and a third for chiefs, a 4th for brush trucks, etc.
To go beyond 1st due, you need a card file or a computer. In the old days, they used "run cards" - every address was mapped to a "box" (in the old days, the pull station on the closest corner) and every box had the entire list of of apparatus, by type, in order they were "due" at that box. Dispatch then read down the list, skipping those that were already out on other assignments, until they'd "filled the box". A second alarm worked the same way, just read further down the list.
Now, most big departments use computer assisted dispatch, but it works the same way - just uses a database to keep the lists, and the computer remembers who's available.
N5MRK
Oklahoma City, OK
I did some quick checking and i have to say... Who ever is in charge of OKC's fire department website needs to be shot or hung.... or something along those lines. Thier website is utterly useless. Anyways... If someone wants to get me a map or list of Fire departments and the addresses i can make a pretty map of it... lol. I might see if i can dig up a map or something later this week. It would simply be a map with the locations of the fire stations. Even though they don't have a specific area they cover, you can usually figure out which stations respond to what based on the location of the call.
Anyways... Thx for the info.
-Matt
