I just picked this unit up, along with a magnetic NMO-style antenna testing resonant at around 50mhz and 150 mhz, for $3.00. I'd never heard of this unit before today, and only picked it up out of curiosity (yard sale item). After researching and finding out how to properly connect the power leads, I at least get it to turn on, and confirm that the speaker works. However, I have no idea of its programming, if any, and when I key the mic, all I get is what I assume is a warning tone of some kind from the speaker (in the roughly 400-600-hz audio range), with no output from the transmitter. I'm connected to a 50-ohm, 1000-watt, shielded dry dummy load, and am running the unit from a 45-amp switching power supply. All positive connections are being made to the same point for test purposes. Does this unit need to be programmed before any transmit test can be made? Is there anything else I may have overlooked? Thanks for any advice.
