MARCS-IP CWID every second
phask
KZZV - SE Ohio
S Zanesville site has been xmitting CWID every 1 sec (or less) for the last couple days. Anyone else seeing this at other sites?
Pro96 can barely keep up with it :)
No idea if maybe part of the software update or just an error.
cg
Connecticut
you are hearing it or seeing what PRO96 is calling CWID? Some software programs created a fake TGID, 65536, to indicate when the BSI was transmitted.
I see the 10000h or 65536 dec ID every couple seconds on several local systems in Southern NE.
It was briefly discussed somewhere else, perhaps Unitrunker Group, and I think it was related to a P25 Core upgrade and it means something else internally on the P25 systems now
chris
mikey60
Oakland County Michigan
If you're talking about Pro96Com, there's an update to handle this.
It's a change in the control channel data. Rules were changed that allow the system to transmit it's call sign on the control channel, without the need to do a CWID every 30 minutes.
Mike
phask
KZZV - SE Ohio
That fixed it... MARCS has been doing a system wide software update - must have triggered it as it was not as issue.
Pretty lax about upgrades - as long as it works and no needed changes,
Thanks for a nice program
Mike
KD8DVR
Columbus, Ohio
This must be why unitrunker is dropping the control channel consistently now.
Sent from my LG-D631 using Tapatalk
j0atm0n
Wapakoneta Ohio
My unitrunker has been doing the same thing all morning on the BEE-348 001-022 Wapakoneta system.
Shows constant group id 65536 on control 774.30625 and occasionally will rapidly trigger on another channel.
KD8DVR
Columbus, Ohio
Yeah, he fixed this on the experimental version that's out on the Google Group. There was another issue that went along with this. There are some systems that had voice over control channel that he patched up too.
