These questions pertain to other than voice transmissions originating from MARCS-IP mobile/portable radios. Generally speaking, are the radios continually communicating with the system, or are these communications relatively infrequent, such as when the mobiles/portables are powered up?
In addition, do MARCS-IP mobile/portable non-voice transmissions appear randomly across all available system input frequencies, or do they typically occur on the repeater input frequency offset by 45 MHz from the control channel frequency currently in use by the system?
Data transmissions from radios to the system are usually rather infrequent but this can can vary. Typically, radios send data to the system upon power-up; when switching sites; when the PTT is pressed; call alerts; and if/when using status or messaging functions (very short canned messages which can be defined as anything an agency needs such as on scene, in service and so on).
This only happens on the control channel input of the site a specific radio is affiliated to. Responses from the system are on the output side of the control channel.
Ohio MARCS also has a feature called Integrated Voice & Data which can use some voice channels of a site for more extensive data use such as Over The Air Rekeying (OTAR, installing new encryption keys remotely), Over The Air Programming (OTAP), unit-to-unit text messaging, geo-location, and mobile data terminals. However, IV&D is slow and not well suited for graphics-intensive functions, so it's rarely used for mobile data terminals. It's also rarely used for text messaging (which is far easier on a personal cell phone). In addition, IV&D is a low-priority use; as voice traffic increases, the availability of channels for data is reduced.
