MARCS-IP Warren County
wolverine
Cincinnati, Ohio
I'm scanning MARCS-IP Warren county on my new RadioShack Pro 651, and it's nice to finally be able to listen to a digital P25 system, without having to move the scanner around because it's garbling up. But scanning a wildcard, I'm only getting hits on the state prison talkgroups, and none of the local police talkgroups such as Warren county sheriff office talkgroups. Did the local Warren county law enforcement switch to this system?
wolverine
Cincinnati, Ohio
W8RMH
Feed Provider Since 2012
You are monitoring the State System not the Warren County System. That is why you are only hearing state agencies.
You should program these:
858.23750a 858.76250a 859.23750a 859.76250c
Warren County is a Tier 4 system.
Tier 4 - Sharing Core Resources
County which builds, maintains and manages their own tower sites and subscribers but shares the appropriate MARCS zone controller. County can determine which talkgroups and agencies may roam to their tower sites.
wolverine
Cincinnati, Ohio
Update: I programmed the frequencies into my scanner, but I'm unable to listen to system from my location as it doesn't receive well and most of the time, I don't receive anything other than a talkgroup coming up, and it sounds like a unit keying up their radio, and then dekeying.
I cheked the frequecies in the system and they are correct. I wonder if it's a setting since I can receive the other MARCS-IP Warren county site and receive state prison traffic, loud and clear.
I selected P25 Auto if that helps.
wolverine
Cincinnati, Ohio
Thanks. I'll give that a try. I currently have the other site frequencies programmed since those talkgroups I receive best.
n8dhw
Middletown, Ohio
Warren County talkgroups will only come up on the 800 simulcast site not the 700 state site even though they share the same tower at ODOT District 8 HQ.
Sent from my SAMSUNG-SM-N910A using Tapatalk
