Mike - that was JUST using -15.00. I could NOT find a FCC ULS liscense list with Dresden's update. As I said- I see the control channel in the HP, but noting as to hearing it. The old Dresden freqs. are quiet. Zanesville still on old.
I have both new sets loaded in an HP1 with alert tones, so I should know when they actually use it.
Curious - is it common to see activity, but hear nothing? Is there some time between rebanding and going active? This is the 1st MARCS one I have experienced.
Paul - N8PFF
Paul,
I don't know anything about the HP-1. But, in general, if a MARCS site gets rebanded, you need to configure that site [in your scanner] to use the rebanded trunking tables. I can't tell you how to do that because I don't use an HP-1.
If you go into the DB and click on "Dresden" site, and hten click on the license -- that license definitely lists the post-rebanding 85x.xxx mhz frequencies along with the pre-rebanding 86x.xxx frequencies.
Once Uniden pulls the updates from RadioREference and then provides them to you HP-1 users, you'll be able to update the site using Sentinel [I think that's what htey call it]. Until then, the only way to do it would be to manually make changes to the site -- and I'm not sure you can do that on an HP-1.
So you may have to wait until Uniden gets the updates from Radioreference and then provides them via Sentinel for you to update your scanner.
When I updated the site in the DB, I set hte 'Rebanded" flag, which Uniden will use to instruct the HP-1 (in a future update of the database via Sentinel) to use the appropriate custom trunking tables that are required for rebanded sites.
Mike
Mike
