Maricopa County GMRS 'Towers 575' machine is disabled
GlobalNorth
Fort Misery
For anyone wondering why the 'Towers 575' repeater is down, the owner of the repeater has shut it down due to bad behaviours on the air. They are trying to get a workable handle on bringing some semblance of civility to the machine.
If you are a member of AZGMRS, check with the club for particulars.
mbnv992
AZ
Yep, I’m a member of AZGMRS and the AZ repeaters have gotten out of control. The Towers 575, 600, Shaw etc etc have been full of dead air key ups, random music, etc etc. PHX550 A ( B T etc ) have been good because of the tones on both RX and TX and you have to be a paying member to get them.
Supposedly the 575 is paid members only and you have to be vetted by not just one, but two members in order to get the new 575 repeater tones.
nd5y
Wichita Falls, TX
How does that work? Non-standard tone?
The most common way is split tones. Transmit and receive different tones. tx DCS and rx CTCSS or vice-versa. The users would need radios with that capability or just use the TX tone and receive CSQ but that confuses or upsets people that think they need a RX tone. The TX tone is "secret". In may cases that's good enought to keep out the riff-raff until they find out that all you have to do is listen to the input and find the tone the instant somebody transmits.
You could use a non-standard tone if your repeater controller or tone board has the capability but the user radios would also need that capability. That works unless you picked a tone that was within the tolerance of a standard tone. You might use 100.1 Hz and wonder why people can access the repeater with 100.0 Hz.
You can manually program a Baofeng for any CTCSS frequency between 60.0 and 259.9 Hz in 1 Hz steps and they do split tones.
Surely people just try them one by one?
You need a brain and patience to do that.
mbnv992
AZ
Did the Shaw Butte repeater change codes too ? For some reason I can’t hit it anymore. That repeater was always full quieting from where I work in downtown Phoenix. Now - nothing. So something tells me the codes changed.
noel62h
I've been trying to reach the 575 on towers. I do a lot of 4 wheeling all over the state. Loved to drive around and see where I could reach it from it was impressive. It's unfortunate people ruin everything. I really enjoyed it. Any idea when they will reactivate it? Will the tones be the same or will that change.... If so who do I contact to get the information?
Foresigt
My GMRS is the place to find information. There is a place to check for access if it's even still on the air. I think it's at least a place to reach the repeater owner.
mbnv992
AZ
Apparently the 575 is now a paid only repeater system. I messaged the owner on my gmrs.com ( KADA48 I think ) and he has yet to respond. And this was a few weeks ago now.
KD7RJC
Meh. I've only fairly recently gotten into GMRS given how the one license covers everyone in the household, and frankly there seems to be a lot of GMRS operators that would be much happier as hams or much happier with cellular PTT radios. I've heard people complain because other people were operating, like they had some sort of exclusive claim to a frequency, and this isn't the first complaint about repeaters that I've heard. Other complaints have revolved around insufficient remaining channels available for repeaters in a given area, basically channel congestion.
The amateur service is by no means perfect, but there's enough spectrum even on just 2m and 70cm to where repeater congestion isn't causing problems.
How does that work? Non-standard tone? Surely people just try them one by one?
I'm not sure how split tone is supposed to help when a receiver doesn't have to use tone-squelch at all in order to listen. It's convenient so to not open on receiving any other transmissions from other stations on the same frequency but it's not going to somehow prevent a recipient from hearing the repeater output. And I suspect that a lot of those using repeaters don't even bother with configuring tone-squelch even if the repeater offers it.
As for the TX tone for opening up repeaters generally regardless of service, my FT-5DR can receive and tell me what the tones being transmitted are even on frequencies that are out of its TX range. If another station opens up the repeater and I can hear that other station directly on the repeater input frequency then I'll be able to figure out the tone that was used.
The only way I see a club managing to reduce problems on their repeaters would be to cycle the tone on an almost constant basis, basically requiring their members to change to the newly-configured tone on a schedule, and doing it frequently enough that it annoys would-be jammers sufficiently to where they just stop bothering.
This is one disadvantage of not having something like the ARRL, there's no advocacy body that will at least try to organize its members to sniff-out the offender to forward on to the FCC. That still doesn't guarantee that something would come of it but I expect that getting the FCC's attention to bad-actors is more difficult on a service that's bordering on being the wild west and anyone with thirty-five bucks can get a callsign.
GlobalNorth
Fort Misery
If the ARRL is a 'valid advocacy' body, then no thanks. They watch out for contesters, but little else.
GMRS is not amateur radio and it isn't CB without static. It isn't to sit on a machine all day and control it for personal means or to rag chew about your 1963 Ford from high school. It has really devolved recently.
The last times I used it, it was in furtherance of a open range geologic stratigraphy class and installing a new HF antenna.
KD7RJC
I guess I'm not really sure what you're getting at, since you refer to GMRS but also refer to bands that aren't part of GMRS. Are you upset about ham radio, or about CB, or about all of it generally?
GlobalNorth
Fort Misery
You can put a group in charge of GMRS and nothing will change. The same goes for amateur radio with ARRL.
Everyone now has rights and not one person has a responsibility to anyone else.
Foresigt
Face it, today's CB is GMRS. It just has reapers. Some good people and a whole lot of idiots. Listen to most of them, they sound like CBrs. Just about everything but the Good Buddy after 10-4. That is why they are both regulated by Part 95.
N9JIG
Sheriff
Moderator
Far NW Valley
All right kids, let's stop with the off-topic-for-this-forum argument. Bring that to the GMRS forum if you want but it does not belong here.
AZ Forum Moderator.
