RobertsRadio
Cobb County will spend $13.3 million to upgrade the 800 MHz Phase 1 digital radio system to Phase 2 technology.
The Marietta Daily Journal - County to spend
I'm pretty upset about this fast upgrade path as a Cobb Taxpayer as well. Just seems too soon. My question is which users are going to go TDMA exclusive and which might stay FDMA for the foreseeable future. I believe you can run both on what they are moving to. I'm also curious if anybody is hearing encryption rumblings, Cobb has traditionally been pretty open listening except for MCS/SWAT.
The $13.3 million is only going to be used to replace the infrastructure at existing tower sites and some equipment in the 911 Center. This money will not be used to replace existing subscriber radios used by the County, cities, private ambulance services and other users of the radio system, nor does it pay for any additional tower sites needed to improve portable coverage throughout the county.
Means you have to upgrade to the PSR 800!
yes it is expected to happen with the 3rd or 4th Quarter of 2014...according to some sources i have..why the push for TDMA PII...and MCS/SWAT are open most of the time...they only encrypt if its a very bad situation...but thats all the info i have right now at this time..but i guess they want to keep the listeners out like our public utility going to TETRA...that was a good move..Could have went P25 or NXDN or TRBO like Sawnee EMC did...but no control over anything..they have the money they will spend it in some way...
K4SVT
To respond about other vendors' radios, the Johnson is still only DUAL BAND. I'd want to push for the Harris Unity, or the seldom-mentioned Datron Guardian II - both of which "get all the channels", and would probably be cheaper than the APX's which, at best, are only dual band. UHF should not be left out in the cold just because some schmuck thinks it's "the security guard band". They want interoperability, they need to "be about it", not just talk about it.
Its called the radio managers...but I'm just stating what i know and have been told...
Sent from my SPH-L710 using Tapatalk
