Marine band freq import
tharsh
disregard.....Marine band freq import
what is the easiest way to program the marine band into the 800? Cant find it in library? really hope I can cut and paste something
I got it, nevermind
ScannerSK
Gilcrest, CO
From the PSR-800 owner's manual:
To use Service Search, press the MENU key to access the Main
Menu, then use the  key to scroll down to the Search option.
Press the ▶/II/SEL key to proceed to the Search menu. Scroll to
the Service Search and press the ▶/II/SEL key to to proceed and
select the type of Service Search you wish to perform. To block
reception of undesired signals found while using Service Search,
press the SKIP key.
To change the Service Search options, press the MENU key
while Service Search is active.
The following service searches are available:
Marine
CB
FRS/GRMS/MURS
Public safety
Aircraft
Amateur (Ham)
Railroad
Shawn
tharsh
thanks
Thanks Shawn, I actually created a quick tab delimited file and imported into a scan list. did the import and it is now selectable with all the others. appreciate the suggestion.
thanks
Tom
