Marine Radio scanning near inland lakes
kf4lne
Bristol, VA
Does anyone hear any activity on any of the VHF Marine channels near inland lakes? I live down the street from Watauga Lake in NE Tennessee and only a few air miles from several of the marinas and occaisonally hear activity on Marine Ch 9(156.45) and I am wondering if anyone else hears activity on any of the marine channels.
ShawnCowden
London, Kentucky
Laurel Lake in Kentucky off 1-75 in corbin has activity on marine channels also lake cumberland near somerset, jamestown ky does u gotta be close though cause they use simplex
kf4lne
Bristol, VA
Yeah, its simplex and usually only 1 watt. Marine Mobile radios are limited to the 88(?) channels and the channels are restricted to what type of use is allowed. They only allow more than 1 watt when you are far out from the station you are contacting. What channels are they using on that lake?
KT4HX
Spotsylvania County, Va
So does a marine radio have an adjustable power setting for times when you are far afield (or alake?) and need to reach the Marina? Never had my hands on a marine radio - as is obvious by my question. :D
Mozilla
South Florida
Marine radios
The max power for consumer based Marine radios is 25 watts for a mobile and usually 5-6 watts on a portable, low power is usually 1 watt. Certain channels require 1 watt or lo-power settings... while most can be run using full power.
Attached is a link... please carefully look at the Frequently asked question section.. it will answer some questions and issues you need to be aware of...and also gives you the channel plan and use.
http://www.navcen.uscg.gov/marcomms/vhf.htm
Hope this helps
