trx680
I was looking at the Icom 7300 on GigiParts website and the offer a mod service. GigaParts MARS Mod Level 5. Looks like it opens up more channels.
What are these channels? Why arent the available without mod?
To make an amateur radio capable of transmitting just outside of the amateur radio bands, this service usually involves the removal of a surface mount component inside of an amateur radio (along with some additional steps).
By having GigaParts perform this modification, you will retain the manufacturer warranty backed by GigaParts (should a problem arise from the modification we perform). Damage caused to the radio by transmitting too far out of its intended frequency range is not covered under warranty.
This service is usually performed for licensed operators from the Military Auxiliary Radio Service (MARS) or Civil Air Patrol (CAP), but we do not require proof of license to order this service. It is the responsibilty of each radio operator to make sure they are in compliance with FCC regulations regarding frequency usage, power output, and accepted equipment.
Icom 7300
Icom 7300
