Some friends with MFEMS told me they recently switched martinsville city to Kenwood Nextedge 9600 UHF trunked, anybody happen to know the trunking info/RAN/ TG IDs for this new system?
Maybe someone in the area with DSD+FL will be able to check it and help fill in the missing information. PLEASE if you find the system info submit it to the RR database so it can be updated.
Watch this video to see how easy DSD+FL makes it to gather the info (and a lot cheaper than a scanner)
That's exactly what you should see. Did you run FMP24-CC.bat ? Basically FMP24 has to be running (preferably via FMP24-CC.bat) and then you run 1R.bat to start DSDPlus. Then they establish a communications link between each other. The error you are seeing is indicating that a communication...
Hearing Martinsville now on this system on the White Oak Mountain site. It shows in the SrcAlias column as MPD VHF LINK on dsd+ so maybe it's a backup for them. Update, also hearing Martinsville Fire talkgroup 64.
