Marysville FD
KD7VOW
Everett, WA
Anyone scanning on the North end, RR database has Marysville Fire on TG's 9872, 9904, and 9936. However, upon programming the BCT15 with these groups, they were nothing but silent.
It sounds like Marysville Fire District 12, and Fire District 20 (consolidated with Fire District 12) Is in fact being dispatched on Snopac County Fire North. I'm guessing that they were merged to Snopac and none of the scanning databases were updated. I wanted to check with others and see input before possibly sending this info to RR Database. Thanks!
lowboy654
DB Admin Member
Northwest, WA
They are on Snopac north control channel 868.7500 right now
lowboy654
DB Admin Member
Northwest, WA
Tell you what they should be dispatched on the east control channel and that would also be north to. I am going to load all dec codes and see what I get on the north control channel and see if I can come up with the dec codes that you listed but I believe that when Marysville came on line with Snopac that they are now dispatched on fire north. so let me reload my 97 and see what I come up with and if so I will fix the data base. thanks for pointing this out.
This what I have for Marysville let me know if this is right.
Marysville City FD (+FD 12)
Station 61: Engine 61, Engine 61A, Medic 61,Aid 61, Aid 612
Station 62: Engine 62, Aid 62, Inspector 62
Station 63: Engine 63, Medic 63 Fire Marshal 28A, Fire Marshal 28B
I will keep this up and running on my 97 for a few days. And Listen for these STA #.
OK Marysville is dispatched on TAC 5 north dec code 720 I am going to let this run for a day or two before i make a change here. I am not in to the fire thing so bear with me and I will get this fixed. you can find fire info here its kind of old, but some of the STA # are up to date.
http://www.northwestradio.net/interceptnw/scfd.htm
I have made this change for now and I will wait and see, unless someone here has more up to date info on this, but at this point I believe that Marysville has been moved and is now on SNOPAC north and is on TAC 5 DEC code 720 and at this time I do not want to delete the Marysville stuff so I just added a note there, stating that they have been moved to TAC 5.
"Marysville Fire has moved to TAC 5 Snohomish County Fire Talkgroups"
Ken
KD7VOW
Everett, WA
Thanks Lowboy654
Yeah, that's what it sounds like. I took the site/group layout on the BCT15 with the Butel/Arc15 Pro software and put the old TG's from Marysville on one Group, and Snopac North on another group. 720 sounds like the ticket.
But thanks for double checking that, that's what I wanted. This is my first scanner, I'm still getting my feet wet for programming systems. Particularly trunked.
And as far as I know, those station/unit numbers are still correct. In fact, Marysville is currently building a fourth station. Still not named. So we'll have another set of units to add to that northwestradio.net site.
