Mass state police help
Powball
So I’m in central MA. Troop C is the state police in this area. My area is C1 but the talk group has C1, C3, C5, C7, C8, C10 . Is there anyway to listen to just C1 without having to listen to half the state? I have a Uniden BCT15x
Whiskey3JMC
Another Pesky Scanist
Simulcastylvania, TE
Welcome to the forums:
According to the database they're all on the same talkgroup so the answer is no. They'd need to be on their own unique talkgroup in order to listen to just them
33840843AC-PTL-3West Dispatch - C1, C3, C5, C7, C8, C10Law Dispatch
ecps92
Taxachusetts
Program for the Trunk using Site/Zone 8 Only and Only program for the Talkgroup of C-PTL-3
that is where Barracks C-1 operated, along with C-3, C-5, C -7, C-8 and C-10
No way to only listen to that One Barrack.
C Troop is broken up as East and West
East being C-PTL-1 for C-2, C-4 and C-6
West being C-PTL-3 for C-1, C-3, C-5, C-7, C-8 and C-10
C-PTL-4 is for C-9
and C-PTL-2 is the Talk-around
Powball
I have it programmed in, but more often than not I have it locked out, because most of the time they are from halfway around the state.
ecps92
Taxachusetts
if you only have C-PTL-3 , they are NOT from halfway around the state, that is ONLY as listed above those C-x barracks
Sounds like you have more than just C-PTL-x in your Scan Banks
StoliRaz
Also make sure you're in scan only mode and not search. Under search all talk groups will come through, under scan only the talk groups you have programmed will be received.
Powball
Ya but if you look at the map, troop C goes from the NH/VT border to the RI/CT border, that spans the whole state. Most of the time I’m hearing the State Police from the bottom of the state and I’m at the top.
Problem is the talk group for Troop C Dispatch is used by all the troop barracks
StoliRaz
Since there are multiple "users" sharing the same talk group then there isn't really much you can do. Monitoring that one TG is going to result in hearing all users of said TG. I don't believe that there's any way around that.
