justanotherguy59301
- Joined
- Mar 21, 2011
- Messages
- 7
I apologize if this has been discussed somewhere else, I did try searching relevant terms.
We are using Tone Control on our area base radio, with 4 wire tone remotes. Occasionally on the line there is a popping sound that comes from the backhaul(VOIP). When the tone remote is keying the radio and one of the occasional pops occurs, the radio will sense a "NO TONE" and the radio will stop transmitting.
It looks like the radio has a function specifically for this, in the Configure Radio>Remote Control section. The 2175 debounce timer according to the help menu should delay the radio from executing a "NO TONE" function for a selected amount of time if it senses a loss of the 2175 hold Tone. I have set that to the max(2.5 seconds), for testing purposes, but the radio still seems to stop transmitting as soon as the hold tone goes away, In my mind the radio should remain keyed for an additional 2.5 seconds after the tone remote ptt is released. I have also tried to simulate the popping by using a momentary push button to short the TX pair of the tone remote, the radio does decode a No tone followed by a return of the 2175 hold tone when I try testing it. Neither the debounce nor adding a timer before the stop remote PTT function in the No Tone table, seems to achieve the desired effect.
Is there something I'm missing (I usually assume there is).
