Mastr executive II PA
kayn1n32008
ØÆSØ
Sector 001
When you say the maxtrac will give me grief below 20 watts what do you mean?
You would be better to get a low power TK-7180(8180) 5-25w radio. They are quite happy to run anywhere in that power range. They also have a DB-25 with all the needed inputs and outputs to interface to a repeater controller.
The other option is to disconnect the PA on your Maxtrac and see how much power the exciter puts out, and if it would be enough to drive the Mastr 2 PA.
kayn1n32008
ØÆSØ
Sector 001
Maxtracs and their friends will turn way down in power, but they seem to keep drawing the same current
and I cant tell you how clean the output is in that state
they get just as hot just as quick
not to mention the way the firmware drops the power back as the seconds tick by
Bingo. You don’t want to run Maxtrac/GM300’s at less than 50% of its max rated power output (12.5w for a 25w radio and 22.5-25w for a high power radio)
prcguy
Most FM radio power amplifiers operate class C and want to run near full output power or saturated and they are usually most efficient there. When you turn them down below a certain point they can become unstable like you set the power to 25%, unkey, key up again and the power is something different. Some transmitters can also get squirrelly and put out spurious signals when turned down too low.
WX5812
Fort Worth
thanks for the reply. I might open it up and see how much the exciter puts out alone. I don't mind getting another radio if I have to, just trying to do and play with what I have. this is a great site and the tips are great!
