MastrIII Rx
KD0ZP
Sioux Falls, SD
I have a Mastr III and the RX Synthesizer will not lock at below 450MHz. At 450.0125 it will lock, I can adjust the PLL lock Voltage! But change the Rx frequency a little bit and the PLL just hunts. It is G3 rx repeater. I have software set for low side injection. Acts like software is stopping at 450 MHz and below. I did not read about this on any how to write ups to make repeater work in ham band. Is Rx below 450 MHz possible?
KD0ZP
Sioux Falls, SD
Low injection is better for image rejection, according to articles I have read. I want to make this work with as small of a change as possible. Lo side is how repeater worked right out of service. To make the VCO lock high is more work. 447 MHz would be fine for my application. I might have to try high side but I don't know the limit there either. Is this 450 MHz a hardware limit? I don't see any error from the DOS program the writes to the repeater. But it does not lock when the program changed 25 KHz, to 450 MHz.
