maury/columbia tn nxdn system
n4anz
I have the BCD536HP. I would like to know if anyone could tell me why I'm not receiving all of the NXDN system. I know that Columbia TN is encrypted according to R&R but from looking at the database none of Maury County TN is encrypted. Am I doing something wrong when programming?
n4anz
Not sure if its true NXDN or not I'm just going by what R&R database is showing I'm new to this digital scanning stuff
milf
Careful, I CAN hear you!
Indianapolis, IN
Try programming it as analog conventional. If you hear an digital growling, and it wont pick up as P25, and you have the DMR upgrade, and it wont work on that... Then it is NXDN/NexEDGE or iDAS... If it is one of those, then you need the Whistler TRX series of scanners as ONLY they can do NXDN.
jimg
So. Middle TN
Programmng Maury County
I am trying to program the Maury County Sheriff radio system into my Whistler 1088. The RR database shows it is a NXDN system. I've never programmed an NXDN system. Is it "DMR"? Also, are there any other factors that I need to consider? Please advise and thanks in advance for your help.
milf
Indianapolis, IN
No NXDN is NOT DMR. It is an completely different digital format. As far as I know that 1088 will NOT do NXDN at all. Only the TRX 1, TRX 2, Uniden BCD436HP, BCD536HP or the new about to ship Uniden SDS100, and forthcoming TRX 100, TRX 200 can decode NXDN. Or a computer with a dongle running SDR and DSD+. Is the Sheriffs NXDN being used yet? If so we need updated on its status, and the RANs in use, and if they are encrypted like Colombia PD is.
jimg
So. Middle TN
I don't know if they are using NXDN or if it is encrypted. I was just looking at the information in the RR database, which I thought showed the system was NXDN, but not encrypted. I was just wanting to program the system into my scanner so if I was traveling through the area, I could receive it. Looks like since my 1088 won't receive NXDN, I'll just wait until the new scanners come out. Thanks very much for your prompt reply!
milf
Indianapolis, IN
SO has NXDN capable radios, and the licensing and was planning on implementing NXDN the last I heard. The rest of the County uses a wild mix of DMR, NXDN, and analog conventional. Thats why I asked hoping someone local would at least be able to monitor and confirm digital in use. That is simple enough lol. But to nab the RAN on each repeater, and TGs in use, and use of encryption requires a little deeper digging. :)
jimg
So. Middle TN
Just another question--do you know if Whistler has an upgrade that could be applied to the WS 1088 so it can receive NXDN?
TRamrod38
Maury Co. Sheriff is using kenwood nexedge radios but are analog on 453.1875 and Columbia PD is on 453.925 and is digital but usually in the clear but can use enc. if needed.
jimg
So. Middle TN
Thanks for the info! The scanner was able to pickup Maury County, but it was just a "growl" on the Columbia frequency--assume it was encrypted.
milf
Indianapolis, IN
No it just means as you were told.. The WS 1088 WILL NOT DECODE NXDN. Even if they were in the clear talking about a recipe for tuna salad, all you will get is a digital growl. Same on ANY NXDN freq. Your scanner can not monitor it. You can verify it is digital NXDN, but you can not hear any voice on it.
Only the following scanners will decode NXDN:
Whistler TRX 1 , TRX 2, FUTURE TRX 100 , TRX 200
Uniden BCD436HP, BCD536HP, SDS100. ***WITH PAID UPGRADE ***
jimg
So. Middle TN
Thanks--I stand corrected.
