Maxtrac 403-430
WX5812
Fort Worth
I have a maxtrac mentioned above and this thing will not even receive outside of that portion no matter what I program in. is there a setting I need to change so it will at least receive in the 434-438 range?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
I press shift to input frequency and it accepts but no audio at all
Mic plugged in? Those radios require that to hear audio. There is a little doo-dad made out of a RJ45 with a jumper in it that will make that work, too.
Also if it’s got a 16 pin accessory connector, there’s a required jumper to enable the internal speaker.
WX5812
Fort Worth
Ok I will get it open and check the voltages. I did find out it will talk up to 432mhz but no receive so that’s prolly the issue
