Maxtrac 888-trunk
kp4ptd
:roll: Just got two Maxtrac 888 and would like to know if can be expanded to transmit above 870.000mhz limit. Edited MDF file and radio accepts 920.000 but does not transmit. Also tried 870.0125 and it does not transmit either. It is loccked at 806-870mhz. Which is the trick to get it to transmit over 870 mhz, if it is possible. Thanks...
FuelForFire
The Garden State
Its not so much a matter of how to unlock it as it is that the VCO simply is not that forgiving. I have never tried to take a maxtrac out of band but I know some radios wont go father than 1 MHz and some with go as far as 15 MHz. It not only depends on the type of radio you have but also the individual radio. I had one astro saber that went 15 MHz out of band with no problems and another that would not go 5 MHz.
You can bitbang the software up to 1.2 GHz if you like but if the radio hardware doesnt like it, it simply wont happen.
Mike
kp4ptd
Mike: Thanks for your comments...just worked out another suggestion and went up 16mhz without changing firmware...I believe that's all it can go up now... thanks again Pedro kp4ptd (you can see my face at www.qrz.com) dont get scared!!!
