bbrasmussen
bbrasmussen,
I need to know more about the UT program. I have the maxtrac with ardunio installed. It works , but in UT when I put in a control freq it parks on that one and I receive it perfectly but only that 1 control channel. I have about 6 control channels I want to scan through. Also why do you need the second maxtrac? I pick up both sides of the conversation on one maxtrac? Can you run two usb ardunio's at the same time? In UT? Please help.
So when I am controlling my voice-following Maxtrac via UniTrunker, I hear only the audio from active talkgroups that I have selected to listen to. When it is parked, it's on a frequency with no carrier, so the squelch of the Maxtrac silences the audio until UniTrunker tunes away from the parked frequency to another call on an active frequency. As far as scanning control channels, I'm not sure UniTrunker can control the radio to do that.
However, a second Maxtrac, as I have in my setup, could help you scan the 6 control channels. My second Maxtrac is sometimes hooked up to UniTrunker as a second voice radio so I can hear 2 calls simultaneously. I can also run the second radio independently from UT and just set it to a control channel and use that as my discriminator audio source for UT. I can set it up so I can toggle through a programmed list of control channels for different trunked radio systems in the area.
In your case you could use a second Maxtrac similarly for scanning discriminator audio. Just program the 6 frequencies into the arduino and set it to scan those frequencies if the squelch is closed and to hold a channel if the squelch is open.
