station32
Has anyone ever tried passing digital audio threw a maxtrac or gm300. Does it work what kind of modifications need to be done.
Thanks in advance,
Thanks in advance,
Yes sorry for the confusion can I take speaker audio or do I need discriminator audio trying to reapeat it what type of modifications need to be done if any thanks
5 Pin style
http://www.batlabs.com/images/maxrpt.gif
16 pin style
http://www.batlabs.com/images/rpt.jpg
full link to all three pages
Maxtrac/Radius Repeater Cable
Thanks in advance,
where would you go to get the flat audio at a pin or is there some sort of modification needed?
Have you looked at the pin out charts for the 16 pin accessory connector on the radios that you are working with?
Pin 5 is flat TX audio input.
Pin 11 is RX audio output, type programmed by CPS.
Pin outs are available at batlabs or repeater builder. In fact, all the answers to the questions you've been asking are already there for the reading.
I was wondering how to fix the pin #10 to enable the radio to power up. Any pointer is really appreciated. Thank you.
Bert
If we're still talking maxtracs/gm300s there is no programming for ignition sense. There is a little green fuse on the logic board back by the accessory connector that you remove to enable ignition sense. Of course if the fuse is blown by carelessness the radio will not turn on. The quick test is the 12 volts to pin 10. If that works either leave the lead on pin 10 or replace the fuse.
