Maxtrac Repeater
W3AWF
Chester County, PA
I'm not sure if this is the correct place to put this so I figured I would put it here. I want to build a GMRS repeater with 2 Motorola Maxtrac's, I have a UHF duplexer and everything else I need to build it. The problem is that both radios are 5 pin radios and usually to build a repeater you need 16 pin radios and use a repeater controller wire like the ones you see on Ebay. My question is, does anyone know how to link the TX and RX radios through the mic port? I know you can do it, i've seen it before but I don't know how to do it.
kayn1n32008
ØÆSØ
Sector 001
Sell, or give away those 5pin radios and grab a couple of 16pin radios off ebay. There are sellers that offer a one way cable to link them together, or spend a couple of hundred for a cat 200 and make up the cables. Do not run the transmitter at more than about 12.5w for a 25w radio, and you WILL want to put a fan on the heat sink.
I have built a bunch of Maxtrac/GM300 repeaters and they are easy to do.
Sent from my iPad using Tapatalk
gatekeep
FAIL 01/93
New York, NY
