Did you buy a RR subscription? That's usually required to import from RR.
Tapatalk doesn't show premium.Seeing how he shows to be "Premium" I'd say yes.
Yes, I did get a subscription. I have to login when I need to import.Seeing how he shows to the "Premimum" I'd say yes.
If you are familiar with Sentinel, you need to drill down through the hierarchy, start with your state, then county, then the system in your county.
For nationwide freqs/systems like marine or CB think about how those are available in every state as options are presented.
What exactly are you trying to download?
I go direct to RR an I see what I need. Do PSREdit500 import using above info an I can not get to what I need for my list.
Your only alternative is to add those frequencies to PSREdit manually under Conventional Objects.Those air freqs. are not listed in RR and I am surprised. I got the freq. from my airport book. I use them when I go flying.
And submit them to RR for future downloads.Your only alternative is to add those frequencies to PSREdit manually under Conventional Objects.
