memo124
On the system
FYI
McAllen police and other city departments are starting to use the system already.
FYI
FYI
Well, I think they're totally off the old system. My Uniden BC346XT do not pick up McAllen PD anymore. A couple days later McAllen FD was gone, too.
Do you have the radio ID's handy? I read McAllen was going to 700 mHz, I can't find anything, though I admit I'm very much a novice.
Well now that McAllen has switched over, I don't know what to listen to. DPS sounds so garbled and computer-ish that I don't understand what they're saying half the time. Guess I'll use that NMO mount for something else. Maybe a cell phone booster?
that's Probably encryption you're hearing from DPS.they are using it more often now,
You think? I can hear words, but it sounds robotic and garbled like they're talking under water. Sometimes it's clearer than others. I wonder if it's an audio setting in my scanner.
ok got ya then it's not encrytion but the result of digital audio,many times not even the dispatcher is able to decipher what's being said,and i doubt it's your radios settings.
That's what I figured. Heard one at the gas station earlier and his radio sounded almost the same. What a tragedy.
What are you all monitoring these days since McAllen can't be heard and dps is garbled?
What are using for an antenna,the rubber duck or an outside antenna.....So I've been listening to an online stream of DPS here in the valley and it sounds considerably clearer than my scanner. How do I get mine to sound clear? Are there settings that need to be changed? I have the uniden bcd396xt.
