KB9_911_SDA
- Joined
- Sep 4, 2018
- Messages
- 1
We have a strange issue that just started with our MCC5500 consoles. Wondering if anyone else has encountered this or knows a fix. Our radio vendor has never run into this issue before. He has tried a couple of things to fix the issue with no luck. He has contacted Motorola directly about the issue and is awaiting a reply.
I am impatient so I came here to see if anyone could help.
We have three CABS/software installs. We have five 800 MHz APX 8500 mobiles in a tray and a couple of older VFH radios in our CES. They have all been working fine for the last year.
Recently we began having the following issue:
When two dispatchers, at two separate consoles, are transmitting on two different 800 MHz talk groups at the same time field units are hearing it as if both dispatchers are transmitting on the same talk group. It also sounds like the signals are mixing together so that neither transmission is fully understood.
Our vendor looked at some settings in our CSDM, he powered down the CES several times and he moved a couple of radios around to different spots and so far none of that has worked.
