Hey all,
I am glad I came across this forum. I work at a fairly active Fire Department that dispatches for several cities.
One thing we’ve noticed, and I think it’s by design, is we have our TG going into a headset and when the talk group is selected and the default audio bar goes right is max (7). You can adjust it but when you de-select it and re-select it again, which is common when you work with multiple Talk Groups, it again goes back to default of 7.
There is no option to adjust this or keep the default the same if you change it. But you can for the level of emergency button alerts in the sound config. Is this an oversight? Is there a way to edit a configuration file? Motorola claims this is how it works and it won’t be changed. Seems like such a configurable option that would be useful.
Anyone else run into this?
Thanks!
Thanks!
