McCarran Airport Disaster Drill In Progress
TOUGHLIFE
A few minutes ago the Clark County Dept. of Aviation began its exercise at McCarran Airport which is done once every three years. The following talk groups are in use with more to come: 37168 and 36912 on the SNACC system for the DOA. TG 42224 the ARFF channel is also in use. If you have a copy of the Southern NV Radio Scanner Book you might look at page 15 (Dept. of Aviation talkgroups), page 15 (EMS talkgroups) as ten hospitals will be involved in actual transports. It's is good listening.
3mary2
Las Vegas, NV
S.Central
the code red on s.central, is that part of the McCarren Training? otherwise there is something happening around the sierra vista area. meto has area shut down and are evacating apartments. heard reference to swat being on location. been in the code red mode for at least the last 30 minutes.
TOUGHLIFE
No, the Metro PD activity that you described had nothing to do with the airport drill. Keep in mind that the LVMPD has an airport police substation that uses a repeater of 155.880.
