GKolo
Etowah City Fire has switched to 800mhz TACN system, If anybody has the talk group lets get it submitted to RR so we can get it added.
Had the same problem with sds 200 trying to identify Sweetwater fireFor some reason the close call on my 436 wouldn't pick up the talk group.
That's what popped up on the scanner when they were being pagedSweetwater Fire has been on Monroe county Foreground 3.
Is the 6025 confirmed so it can be submitted ?
This is the correct one for Etowah fire dispatchJust heard Etowah fire dispatched on 6025
Ok but just a heads up I have been hearing traffic on 6014 alsoThis is the correct one for Etowah fire dispatch
Would you share in more depth what the errors are? And, whose legit radios are programmed incorrectly?As a side note. The Monroe County TG line up has some errors listed on R/R and on some subscriber radios in the field which is adding to confusion in that county. Due to the usual Monroe County politics, these issues have not been fixed since Monroe switched to P25 Sys. 2A5
I heard what sounded like 200 units talking didn't catch what traffic they were onWhat you guys are hearing on McMinn County Fireground-1 (P25 Sys. 2A5) is a patch from the NXDN system, as needed from various NXDN talkgroups.
No, I will not.Would you share in more depth what the errors are? And, whose legit radios are programmed incorrectly?
k denNo, I will not.
