MCS2000 accessory connector wire
RolnCode3
Sacramento/Bay Area, CA
Remote mount MCS2000 has a connector wire that plugs into the radio chassis. I thought it was an ignition sense but the radio works without it. Had speaker issues when first installed, but that stopped after a few power ups. Also showed a FAIL 01/97 on the first few power ups.
All of those issues have disappeared, but the wire is not connected - although it is plugged into the connector on the chassis. Should it be connected? What does it do? Did a search but couldn't find any info.
Thanks.
fineshot1
NJ USA (Republic of NJ)
Thanks.
We would need to know which pin in the DB25 accessory connector the wire is attached to in order
to try and determine and answer to your question.
Also - are you sure it was 01/97 as I do not see that error code on the chart for an MCS2000.
