MCS2000 boot loop
Mjsff4
I’m working on a new to me MCS2000 model ii 110w dual head set up, I’m running into the issue of it being stuck in a boot loop when both the control heads are attatched to the cable with the ignition sense wire and power wire being gave 12v + but when either of the control heads are disconnected the radio will run through the self test and work correctly as soon as the secondary head is connected it begins running through a boot loop no matter what position the heads are placed. The only thing I do not have as it is still in shipping is the rear amplified speaker for the rear control head and I’m not sure if that would cause these symptoms or not. Attatched is the info from service mode along with a picture of how far the radio boots before it resets. Any info would be a great help! IMG_3821.jpegIMG_3820.jpegIMG_3819.jpegIMG_3822.jpegIMG_3823.jpeg
a417
New to you, but did the old seller have it used in this fashion?
Mjsff4
It came out of a decommissioned ambulance and was set up for the dual head mode when it was removed, all the programming supports this when the one head is removed and the radio boots all the way
a417
I hope you got all the pieces of it, and the correct ones at that. I have seen many units like that get removed from a decommissioned apparatus, and be damaged in the process.
First thing to look at is to make sure the wiring harness wasn't damaged in the process. Then I would start looking at the control heads for damage or shorts in the CH plugs and accessory plug areas.
Is it mid or high power?
a417
Are you positive the wiring is undamaged? If you're getting bootloops instead of errors (in the control heads), I'm thinking it's a short.
