MCS2000, can't put in zone names
ryan81986
I'm having no problems programming the channels in the zone, however the part where you would write in the zone name is greyed out. Is there something else I have to put in first? The ID no for the radio is M01SKM9PW6AN if that helps.
Mr_Observer
That field will be greyed out of the character limit for the zone is set to zero. Go to your display and menu and reduce your channel text size. You will see that for every character you remove from the channel text size you get one character added to the zone text size. Now you can edit your zone name ( and re-edit your channel names that are now probably too long)
MR_O
ryan81986
Ah okay, I forgot that the zone is placed before the channel name on these radios. I was hoping that I could set it to only show when trying to select a zone.
Skypilot007
Medford, NJ
Unless it a model III. Those have the zone name or number on the top line of the display and the channel name or number on the lower part.
