Md-380/390 Analog
Meestor_X
When this radio is used in analog mode, does it still have the private/group call functions?
Sent from my iPhone using Tapatalk Pro
Meestor_X
Gotcha. Thanks for that.
If I am using different analog channels for groups of people, is there an all-call function (meaning something that calls all channels at once) in analog mode? (Sorry for my lack of understanding of how these hybrids work).
Alternately, can the radio be set to "scan" for any incoming message on a particular channel when in analog mode?
e.g. If channel #1 is the "all call" channel, and each user is on a different channel, and the radio is set to scan both the channel it's on as well as channel #1, and then a user places a call on channel #1, would everyone hear it?
If so, does the radio then "change channels" to channel #1 for a period of time?
Just trying to understand more about how analog radios work in this scenario.
hill
Middle River, MD
Yes, this radios have the ability to scan. You just make a scan list in the programming software and add the channels you wish to have in that scan list to it. Also have a tab in each channel to enable it.
You change the amount of time it hangs on channel within each scan list. Also change the designated transmit channels when scanning. Can have the transmit designated channel the selected channel, last active channel, or can pick any of the channels in the radio. I always chose selected channel, but know everyone likes something different.
hill
Middle River, MD
Didn't add this answer to your above question, but no the radio can't transmit on more then one channel at time, as such no all channel call. As I posted above the radio only has the ability to operate on one channel at time. This is true in both analog and digital modes.
Meestor_X
I see. Great info, thanks!
So, when the transmit channel is set to say, channel #2, and the radio is set to scan channel #1 as well, if a call comes in on channel #1, can the radio be set to transmit on channel #1 for a short period of time and then revert back to channel #2? (Similar to how my currrent DTR radios work)
hill
Middle River, MD
Unsure if can act the way you said, since think it would stay on the last heard/used. The only way to make revert to back to channel 2 would be have it programmed for the designated channel being channel 2 and would also be the transmit channel. All my commercial Kenwoods, plus the TYT Radios are always programmed to have the selected channel be the revert and designated transmit channel which works best for me.
chief21
Summer - Western NC; Winter - Tampa Bay FL
Yes. Look for Scan / Analog Hang time under the Settings menu.
John AC4JK
